- Messages
- 34,371
- Solutions
- 2
soak in wd40 and leave overnight
Discuss Tiling... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Do they have an allen set screw holding the cartridges in? I've come across these on (from memory) Grohe showers. You screw the cartridge in, and then fix it in place with a screw which goes into the side of the threaded part of the cartridge. If you don't take the screw out it is impossible to remove the cartridge.
the question you got to think of where am i going to get tiles to match as they will crack
Jay if you are extremely lucky and who ever stuck the tiles on used poor adhesive you maybe in with a chance. But I doubt it.
I am assuming the tiles are on plasterboard , if you have a multicutter scrape out the grout and carefully cut through the grout line straight through the board as well , in other words the tiles will be untouched and still stuck to the board.
Bung them in a bucket of water for a few days and the adhesive should scrape off.
Yes a load of work but it does work , I have done it loads of times
Good luck lol
The tiles are on ply..
Reply to Tiling... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
