Discuss Tiling... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
Went to do a private job and change the cartridges in this tap and both are seized into the tap. So have to replace the tap.
Have to remove the tiles which sit directly underneath a mirror above and a glass shower screen to the right.
If I manage to get the tiles out without recking the mirror or the screen, I'll have to chop off a fair bit of the ply to get to the tap.
Question I pose is, what's the best way to put the ply back so I can have my first attempt at retiling once I've fitted he new tap???
Lol i would nt worry about putting the ply back , your main problem is getting the tiles off lol
honest opinion can you get access from behind?
I'd try harder to get the cartridges out lol! Maybe take a socket set or apply lots of heat, are they reverse thread? Looks a pig of a job to change the taps lol
once you've removed the mirror and screen so you can get the tiles out and got the tiles off, if you cut the ply back to the nearest timber and ply from there or cut the ply and screw a 2x1 timber to the ply so you've got an 1" lap each side so your new ply has something to screw too
I didn't check if they were reverse thread as they seem like normal ceramic cartridges.. I tried a box spanner with a Tommy bar, large grips, large adjustable and nothing budged them. Gonna go see now if the new cartridges are reverse thread ....
I'm not removing the mirror or the screen.. I'd rather just hammer the tiles to bits and remove them then go to all that trouble lol
Definitely not reverse thread
Reply to Tiling... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My plumber fitted a shower, 2 of the walls are glass panels and one is a tile board (wedi board). He joint the wedi board pieces (3 pieces) close...
I'll start this by saying I'm hoping to sort this by diy / minimal professional help as I'm a very tight budget! I've got a walk-in shower in a...
Can anyone tell me where I can get a walk in shower enclosure glass wall channel with about 50mm - 60mm of adjustment in it? I hired a bathroom...
Hi all, I'm having problems with an old kitchen mixer tap.......the cold side is dripping from spout so I attempted to remove the brass...
Hi everyone, I'm new here! I've bought my first house - needs a fair bit of work doing to it, including the plumbing. I'm keen to do stuff...
