T
techie001
Hi all, could anyone tell which ports to fit a tigerloop on Riello 40 oil pump and do i need to prime and how to prime. Diagrams welcome, Thanks
Discuss Tigerloop Setup Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
LOL, a bit its only my own boiler. I like to be a hands on. The boiler is on the second floor and there was a lift pump which quit and no longer made, so no parts. I was told to go with the tigerloop.Was looking a little guidance in the correct configuration of the inlet to the tigerloop i have the loop fitted with the inlet to pump correctly and the supply to the loop. Was looking to know does the second oil line from pump going to loop go beside the pump supply or were the bleeder is
I don't entirely know how to phrase it any differently. A tiger loop will not do what you are going to be expecting it to.
It will pull that height no problem croppie
Yes its 10mm oil line
Reply to Tigerloop Setup Help in the Plumbing Jobs | The Job-board area at PlumbersForums.net
