Discuss Thoughts on quote of boiler replacement in the Gas Engineers Forum area at PlumbersForums.net
Hi guys, been quoted 1550 for direct replacement of baxi combi 105he with a baxi 830, I know the engineers.. So paying roughly 500 for Labour. What do you think? Plus this is with thermostat fitting etc. I thought about 1300/1400.
Tbh I would say that’s cheap but if you know the engy he might be helping you out
roughly the kit comes too around £11-1200 so around 300 labour
does that include a flush ?
Sounds cheap too me by the time you allow for pipe, fittings and all the consumables needed for a boiler swap
Does the gas need upgrading?
Will the system be flushed?
Lime fighter & shock arrestor needed?
Boiler plus controls?
Its all great trying to get the cheapest price but if its not fitted properly the warranty will be worthless
Thanks Shaun, not sure if it does include a flush. I do the know engineers from work. He did say that they would usually charge 900 to fit.
[automerge]1581170440[/automerge]
Thanks Scott, includes pipework, not sure about the other points you have mentioned. These are corghi registered engineers who carry out these works often.
[automerge]1581170470[/automerge]
Gas Safe registered etc
There is no way anybody can do this for 1300/1400. The 1550 that you have been quoted is a bargain providing everything is done correctly so I would advise you to take that I doubt you will find anyone else to do it for that price
Too cheap, cutting corners somewhere.
Tail light warranty.
Thanks J, I do know them so they are doing it cheaper for me, he did actually say it would usually be about 1900/ 2000. Thought I'd check just in case with you guys that know. Thanks again.
For me it’s too cheap to be genuine.
It’s £1200 for boiler, flue, lime fighter, shock arrestor, chemicals and cheap controller.
leaves £350 for 2 men, 2 visits and a few hours of admin.
Also pipe, fittings, clips, flux, solder, screws, plugs, sand and cement. All assuming gas and condense are already adequate.
Then someone has to collect boiler, clear waste and hope don’t get a call back.
have you had a formal written quotation ?
You will require a new flue you can’t use anything from the old baxi
also does the company allow them to carry out there own work after hours eg competition as most don’t also they will state there not qualified out of company time etc
Reply to Thoughts on quote of boiler replacement in the Gas Engineers Forum area at PlumbersForums.net
Hi I've been to a customer today that has a 9 year old baxi duo tec40kw boiler,it runs 20 radiator that all work fine,they have 2 bathrooms and 1...
Hi All, what's the cost of a service for an unvented system ? (valiant boiler & mega flow cylinder). I was charged £320.00, for the following...
Hi. I’m new here and due to have a new boiler fitted. Does anyone have recommendations or thoughts on either the Worcester 8000 40KW Combi or the...
Hi, I'm hoping someone here may be able to help me out with an issue I have with my baxi duotec boiler. Basically, the hot water temperature has...
Had a call to a 82 Old man, he paid these £300 up front for a years cover, and I find out on arrival he's been waiting for 3 weeks, no heating or...
