Discuss Thermostatic Shower Install in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hello...
I have a Hudson Reed shower to install but don’t get this...see picture below..
The problem is once I do up the compression joints then the large O rings will not be flush against the wall...there is about two millimeters of distance between O ring on the large nuts and the wall..
Reply to Thermostatic Shower Install in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
