Discuss Thermostat hit and miss with boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hi guys
I have had a new boiler installed, an ideal logic 30k system boiler, with Danfoss rf thermostat RET2000b-rf+rx1-s, wireless. I have had problems with boiler not turning on with thermostat and sometimes not switching off, the installer has now moved the receiver even closer and I am still having problems, the signal sign is showing on thermostat and so is the heat sign. The receiver ch button is on red like it should be but boiler does not come on, today nothing happened for ten minutes so i turned the thermostat to off twice and back up, then it worked.
Any suggestions what the issue might be?
pixs attached is it helps
I think you'll find this is something in the boiler as I had a similar issue with a vogue combi (Ideal) where it would turn on but not off. They attended under warranty as all equipment was from them and they ended changing something in the boiler although the customer doesn't know what
Hi JVTrades, its only not switched off once or twice but my main issue is it does not seem to come on when I set temperature especially first thing in morning when boiler has been switched off overnight.
The receiver was about 15 meters away, it should work upto 30 meters but there were a few walls in between and now that has been moved and the distance from receiver to thermostat is roughly 3-4 meters with one wall in between. The receiver lights up when i turn thermostat up, its the boiler that doesn’t turn on when it should do
Its hit and miss, sometimes it comes on within seconds and then likd this morning I waited 5 minutes and nothing happened, then I switched the thermostat down and up again then it came on instantly, it is intermittent. Got boiler installer and electrician coming on Wednesday to check boiler as well as thermostat /receiver.
Is it 240 or low voltage controls? I'd be checking the sl from the thermostat receiver is sending 240 then checking the boiler terminals are receiving it, could be as simple as a loose wire, or a faulty stat.
Or if the boiler is receiving current but nothing happening then contact Ideal and go the warranty route.
No idea about the voltage myself but the thermostat/receiver was replaced today with a new one, exactly same, said it was working fine until I came home n checked it was doing the same as above hit n miss. The boiler was only installed 4 weeks ago alongside the thermostat. Now the second one is still doing the same.
hum ......... in an empty field.
are you sure the boiler is set to constant?
I have a timer which is always set to on all day during daytime and off night time as we don’t have heating on during night. Then I have this Danfoss thermostat which is purely to raise or lower temp, it is not programmable. This issue occurs during day when timer is set to on.
Pretty sure this is boiler related. In the Vogue there’s a link that needs to be removed when commissioning that’s easy to miss. Could be something like that that’s interfering with the switching. Talk to Ideal and explain the issue they may help with something like this even if not an installer.
if the hot water is working ok but not the heating its not a boiler problem as common switched live to boiler for both unless youve got weather compensation fitted then seperate switched lives needed
One thing I have noticed it works fine when im away from home or should I say when my car is not parked in garage, apparently they both run on the same frequency, maybe an interference which the thermostat cannot cope. My gas/electric SMART METER goes off/disconnects as soon as I park my car, comes back on when I drive away! When I disable the sensor in my car the smart meter comes on.
I bet you don’t get free gas and electric though, if you do maybe smart meters do have a use.
I've had a similar hit-and-miss with room stat MT10 RF (battery operated) paired with Worcester Greenstar 25 si Compact Combi. Technical Support at Worcester-Bosch told me the stat has an accuracy rating of +/- 5 deg C which is useless. I've tried turning the room stat to max and relying on TRVs but I reckon TRVs also have a similar accuracy range. If I throw money at the problem what do people recommend?
You said, the boiler is switched off over night. Do you mean you kill the power to the boiker over night?
Depending how stat has been wired, turning power off can cause stat to loose communication with receiver. You don’t need to kill the power over night. If you do loose power you might have to press reset button on stat.
Reply to Thermostat hit and miss with boiler in the Plumbing Jobs | The Job-board area at PlumbersForums.net
