Discuss The only pipe cutter you will ever need... in the Plumbing Tools area at PlumbersForums.net
Looks great for new installations, not very useful for alterations in place though. I'm perfectly happy with my slices and old style pipe cutter on the rare occasions I use it, only when working on sizes bigger than 28mm.
I bought one after someone revived this thread, lovely thing actually. Works beautifully with little deformation, high quality pipe cutter.
How little can you cut ?
Yeah, first thing I tried...at a push if you're careful and rotate the pipe in the jaw initially to get it truely scored, between 3 and 4 mm. Around 4mm then if you take into account the thickness of the cutting wheel.
Reply to The only pipe cutter you will ever need... in the Plumbing Tools area at PlumbersForums.net
I am in process of replacing an existing sink with a new stainless steel one. The existing tap is plumbed directly to copper which means that it is earthed. The new tap will use flexible tails and so will not be earth bonded. My initial search for information suggests that there is no legal...
