Discuss Testing from a Cube of water in the USA area at PlumbersForums.net
Hi
Just looking to pick some brain's, I'm doing some second fixing, the contractor has a rig sent up of testing with a cube of water and a multi stage pump to fill a storage tank in the roofspace feeding a booster pump, but is there a better was of transferring the water from cube to storage tank?
Thanks in advance
What? Am I being thick? What are trying to achieve? What is actually being done?
What do you mean by cube of water?
Iā€™m guessing the water isnā€™t on and they want to test the systems
So there using an ibc and a pump to pump the water from the ground where they have temp water upto the loft tank etc
What I had in mind.
If theyā€™re on second fix, Iā€™d assume the loft tank pipework is in, so just attach a hose pipe to tank feed?
What I had in mind.
Might not have enough pressure to get up there
If you want to test the system for leaks why not use a proper purpose made hand pump water pressure tester with guage? Use push fits to link / cap all ends of pipes and away you go. Pump it up with water and check gauge 12 hours later to see if any PSI lost.
Reply to Testing from a Cube of water in the USA area at PlumbersForums.net
Hi, Can anyone advise as to why the cold water to my bathroom keeps airlocking? This originally happened about 12 months ago and has happened 3-4 times since. Itā€™s an upstairs bathroom, fed from a tank in the attic. The tank is about 8 Meters away and feeds a bath, sink and toilet. The tank...
