Discuss Techflow QT80-1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
K
kkelly77
I'm trying to find a service manual for a TechFlow QT80-1 twin ended, positive head pump.
I'm currently stripping one to try and find the fault so I can order parts from TechFlow but running into difficulty as to how to get the pump apart.
I have both end covers off and have found some small plastic remains at one end. The impellers seem to be in good shape so I'm not sure what is the source of the plastic shards. Are there specialist tools needed to get the washers, springs etc off the motor spline?
K.
have you phoned techflow? 01444 258017 for technical helpline.
No. I'm in the RoI, so calls would be pricey.
Do they offer helpline support to out of warranty pumps?
Just went back to the pump there and, after drying out a bit, the problem is pretty obvious. Looks like one of the impellers was grinding into the housing for some reason. I've attached a few photos.
Could this be because the retaining bolt on the plastic housing was over tightened? The housing/impeller on the other end of the pump is fine and yet is put together in exactly the same way.
could be a spacer is missing. is there one at the other end?
it would have to be massivley over tightend and even then id be doubtfull more like spacer missing or gone crash bang wollop
Reply to Techflow QT80-1 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My house was a bungalow that was extended up into the roof, and a bathroom installed up there. The hot water cylinder remains on the ground floor...
Hello all, I have a WorcesterBosch Greenstar 42CDi classic combi, which is providing DHW fine, but not heating. Was working fine in spring...
5K
Hi everyone, I'm looking for some advice please. My system has 5 Drayton Wiser TRVs. There are 8 rads over 3 storeys and a 170l unvented...
2K
I normally hire a machine however I'm getting to the stage where I should look at getting my own but f#@k me they're expensive! I thought 'well...
2K
