Discuss Tap or spout problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
dsd
Hi, my kitchen spout leaks if i dont really tighten the hot water tap.
anyone advise me on, is it a tap washer problem or spout washer problem.?
Probably both. I'm assuming you have a tap with a swivel spout. If it leaks from the point where the spout joins the body of the tap, then if it only leaks while the taps are on and for a short time afterwards, its the spot seal. If it leaks when the taps are off, then its is one or both of the tap seals and the spout seal.
Thanks,
let me be clearer, it leaks from spout head if i dont really tighten the hot tap, much tighter than usual. Then it stops leaking.
so you think it can be a spout problem or hot tap seal problem
Reply to Tap or spout problem in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi bit of a weird issue, I installed a grohe bathroom tap successfully 2 months ago bought from screwfix. Last week the right hand hot tap makes a squeak noise as I turn it on or off, left tap is 100% perfect and noiseless. This grohe tap is like one unit, so no screw notch or way I can remove...
