Discuss tap head in the Plumbing Jobs | The Job-board area at PlumbersForums.net
R
REDSAW
anyone recognise this one? even i am stumped for replacement valve!.
cant even see or id the nut to take it off?
is that a posidrive cross head sure in the middle of the black, that will just be an adaptor that comes off and just leaves the splines on the cartridge
yes, they are used for slot on heads. ideal and armitage use them for interchangeable 'handle styles' but search cant find them1
look at the valve nut, like a keyway?
thinking they are cheap chineese tat!
see what you mean just get some new ones dont think you will find them
Reply to tap head in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Have a sink basin tap photo attached and need to replace the heads as behind they have cracked. Any idea where I can get replacement tap head covers only need to change the tap head covers really Problem is the old tap head covers wont turn! Any ideas please? Thanks
I need to replace the washer of my kitchen mixer tap as it is leaking. I was able to remove the spout once by unscrewing the screw on the back of the tap. However now I can't remove it again as it seems I must have used the wrong screw head and have rounded off the head. Please see attached...
Hi, I thought I'd share my experience of dealing with Aqualisa about their Quartz Digital Diverter. When selecting the slider rail handset the water would also constantly drip \ stream water from the overhead rain head. When selecting the rain head the pressure was very reduced and the water...
i can't tell if my shower tap (cock stop) is leaking or not ...............so after showering, the shower head will drip fast for 2 hours, then drip slowly after that...........i put a bucket under the shower head to collect the water for 26 hours the first time.............then 19 hours the...
Mira shower head. Does anyone know anything about this shower head (I will post pics) Its gotten a bit dishevelled, does it come apart easily & then just unscrew to replace with a different one ?
