Discuss Stuck Lockshield Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
N
nrico2006
Was wondering if anybody had any tips on how to open/close the lockshield valve on a radiator?
I have one valve that did not budge when I attempted to move it with a set of pliers. Is more force required (adjustable spanner?). I was hesitant at putting too much force on the valve in case I damaged it.
Would it be an idea to slightly loosen the gland nut?
Thanks in advance.
I had the same a few times now and in the end had to replace the whole thing as it was well and truly stuck. Try more force with adjustable just steady it with a pair of grips. Be prepared for waterworks.
You could try gently tapping both the body and the spindle and/or squirting a bit of Plus Gas spray around the base of the spindle and let it seep in. Don't apply too much force or you could snap the spindle.
Reply to Stuck Lockshield Valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Bathroom towel rail with straight lockshield valves as in picture. Can't remove the top to tighten gland nut as it is leaking. Must be possible to...
Heating system is 14 years old. On inspection I find that every lockshield valve is fully open. After adjusting some, I find that they weep...
Hi all, have a radiator in the hallway which has never worked. When I bled the radiators few days ago I checked the hallway one, and it appears to...
Hello everyone! I purchased this steam vent valve: Hoffman Steam Air Vent 40, 1/8" Angle Steam Radiator Air Valve 401440. Installed it and the...
My kitchen radiator is filling with hot water despite my TRV being set to 0. It's blazing at maximum. This goes for the rad when I try two...
2K
