Discuss Strong fumes, dodgy central heating in the USA area at PlumbersForums.net
Hi, I'm new to the forum and new to oil boilers. I have an older Worcester Heatslave 18/25 (13 years). I've been in this house for about a month. I had an engineer do an inspection before moving in and he said everything was perfect. Since then I've turned on central heating and water heating a good number of times. All seemed to be working okay, until today.
This morning I had the oil tank topped up (from 30% to 100%). The boiler was turned off during this time. After 30 minutes or so I started to smell fumes in the house. I opened the windows to air it out and after another 30 minutes I tried turning the central heating on. It didn't do anything. I waited for a while but nothing, and the smell got stronger. I then tried to turn the water heating on, and that worked right away.
I ended up calling an engineer to take a look at the boiler but they could not find a fault in it, even though I told him water heating and central heating could be turned on independently and this was not working. He managed to brute force turn on central heating by turning on both water and central, and clanking the heating intensity button up. Thermostat was set to 20C and it was marking 17C so heating should turn on. He said I needed a plumber, not an oil engineer.
An hour later I'm still getting very strong smells whenever I try to turn central heating on, and have to air out the house, which defeats the purpose.
I'm located in Aldington (TN25) and wondering if anyone would have any idea of what could have happened. And would you recommend a professional I can call in the area?
Thank you in advance
Are you certain it’s fumes? In my opinion, if you’re getting fumes, then you do need an oftec/oil engineer ASAP, one that has fumes investigation as well. Where is the boiler in relation to the fumes? Is it possible for fumes to be coming from elsewhere? Can you post a photo of flue arrangement?
Also interesting to see a photo of which room the boiler is in, room ventilation, and is there any kind of enclosure for the boiler e.g. cupboard and how is that ventilated.
Cheers,
Roy (amateur)
How would one troubleshoot if it's fumes or not? All I know is that the whole house reeks of kerosene since this morning, and I have several windows open. I began to feel ill (dizzy, nausea) downstairs where the boiler is, because the smell is too strong. So I haven't turned it on anymore and it still smells a lot even with windows open.
I'll take a decent picture of the flue tomorrow in daylight. It's located about 2.3m from the ground.
Cheers,
Roy (amateur)
The boiler is in a kitchen cupboard under the counter. I'm not sure how it's ventilated. What would the ideal ventilation look like?
The kitchen has no door on the opening to the living room. There's a window in the kitchen to the back garden.
I wouldn’t know, as I’m not an oil engineer, however the issues you describe along with your symptoms suggest it’s fairly urgent.
Can you let us know what he says? Thanks. Hopefully he’ll have the experience.
So the boiler was indeed leaking. The oil pump was dripping into a puddle of oil, hence the awful constant smell. He smelled it as soon as he came in the front door. He said the pump will need to be replaced and that the nozzle should be changed along with it. Also, there was a clamp just sitting there which he said should be securing an exhaust hose. He'll also service the boiler when he repairs it. Basically the guy I had inspect it didn't do a good job at all ☹️ I'll be a few days without heating or hot water but at least it's not in January.
Reply to Strong fumes, dodgy central heating in the USA area at PlumbersForums.net
Hi. I hope some one can help. I have a condensing oil burner and it runs fine but the radiators don't heat. Heats the hot water fine. The pump...
Have a sytem boiler with unvented cylinder with 2 heating zones plus hot water in a house we moved into recently. To start with we were always...
Hi, Over the past few months, my wife and I have noticed a constant pulsing sound throughout the house which is particularly noisy at night (this...
Hi all. Could someone help with a issue I have been having with my vertical radiator. I have one vertical radiator in my bungalow and it does not...
My heating system comprises an Ideal Logic 12 boiler located downstairs and a Gledhill OV SOL cylinder located upstairs . The problem is that when...
