Discuss Straight shower swaps. Jade 3 and Ivory 3 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Had both these jobs come in today, The Ivory 3 the customer is happy to spend a bit of money as she was not overly happy with the Ivory. 8.5kw.
Any advice/recommendations on what would be a good swap for this?
The Jade 3 (Also 8.5kw on 6mm) They want the cheapest possible so will probably go for the Triton Enrich from screwfix.
are you uping the elecs as 6mm?
depending on run and fuse would be max 8.5kw normally 8kw
and mira sport are good showers (multi fit)
The Ivory is on 10, the Jade will be getting upgraded.
Just had a look at my old posts and saw that I fitted a Mira Jump last year which was reasonably straight forward so will more than likely go with that.
good good and jumps are ok 9.8kw is more than fine
Reply to Straight shower swaps. Jade 3 and Ivory 3 in the Plumbing Jobs | The Job-board area at PlumbersForums.net
My step-daughter bought a 50's end-terraced house at the start of the year, and found there was a leak from Mira bar shower that was coming...
2K
Hi, A customer has sent me a picture of a gainsborough 8.5 es shower. It no longer gets hot, after speaking to the manufacturers they have said...
  • Locked
My mother has a rented-out property at the above postcode. She's lives abroad and is stuck, and I am in a similar situation. Existing boiler is...
1K
Hello, I am renovating an old stone house in France - about 900 years old at the oldest part - and we are trying to use authentic materials in all...
3K
Not sure if this is a success or a fail or just a rant but We do have heat and hot water now So all started the evening of Friday the 12th (Nov)...
2K
