Discuss Stopcock cut out, what fittings to replace? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi guys.
Been to that stopcock job tonight and the customer has asked me to cut the existing one out and replace.
The pipework will be getting upgraded to copper/mdpe at some point apparently.
Can someone help with the fittings needed? see pics.
The end of the stopcock with no fitting attached was screwed in to an elbow and the other side has obviously been cut.
I'm thinking bush(?) in to the elbow with fitting and section of pipe added. Then the new stopcock, what is the best fitting to connect to the cut pipe? Johnson coupling? Is that ok long term though??
Any help appreciated.
Take it to a good merchant, from memory a Johnson fitting would do.
Reply to Stopcock cut out, what fittings to replace? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
