Discuss Sottini ceramic disc valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
C
craigskelly
I have a Sottini bath/shower mixer which uses a 1/4 ceramic disc valve. The retaining clip is broken allowing the spindle to rotate fully (not just 1/4 turn).
Does anyone know if it is possible to buy a new retaining clip or do I need to buy a new valve assembly (have been told Ideal Standard are compatible)
Normally replace the cartridge as a complete unit.
Reply to Sottini ceramic disc valve in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi - I want to replace Aqualisa power shower to mixer shower to a std. mixer shower, however, the centres for the hot and cold are only 65mm. I’ve...
Hello, and thanks for taking the time to read. I'm trying to work out if the idea I have is practical? The water pressure in my newly renovated...
W
Hello all. I have fitted three new Saracen timed flow valves to existing shower rooms. But these valves are still allowing water to flow from...
I'm in the process of refurbishing my bathroom. I'll be replacing the existing bath with a walk in shower. Will be installing a thermostatic...
T
I am redoing my bathroom and not sure what the best way of doing my shower is which is in my bath, I want a rain shower and so I was thinking of...
Thermostatic shower
T
