Discuss [SOLVED]Pressure 0.0 bar - Glow Worm Home 15s in the Central Heating Forum area at PlumbersForums.net
Hi everyone,
I'm the head tenant of a shared house in Dublin, which is heated with a Glow Worm Home 15s boiler.
This boiler was working fine this winter, is usually set the heating temperature to 45 degrees. But today the weather was pretty warm so I lowered the temperature to 22 degrees for the afternoon.
Now it's 5PM it's getting colder so I tried to set the temperature to 45 degrees again.
Unfortunately the display is now flashing "0.0 bar"
Does anyone know how to repressure this boiler?
There are several videos about this issue on YouTube about Glow Worm boilers but my model is slightly different. I can't just turn the two pipes on to repressure because they have no wheel to let the pressure in.
Can someone help me ? Thank you :)
Underneath the boiler a blue knob ?
I can't see something blue, maybe i have to open the front door but i don't want to void the warranty
With a screw driver I already turned on the two pipes with a black plastic but it didn't help ( the pipe on the left and the pipe on the right )
alright it works now we have 1.2 bars pressure. I update this post, maybe it can help someone in the future... I called the landlord, the problem was not related to the boiler itself. It turned out there is a pipe upstairs, I had to open its valve for 30 seconds, the time to send the pressure into the boiler which is downstairs. The boiler now works without I had to touch it
Reply to [SOLVED]Pressure 0.0 bar - Glow Worm Home 15s in the Central Heating Forum area at PlumbersForums.net
Hi I have a Glow-worm back boiler which is giving me grief (I would have upgraded it by now but its a listed building and there's issues with...
Hi Have a Glow worm Flexicom 30cx-Installed 2010 and regaularly serviced. Last service October 21. Works fine, with no issues. However it has...
Hi, I just moved into a new house and it has a Glow Worm Compact 24c combi boiler and a ESI ESRTP4RF+ programmable room thermostat and I am...
Just been to a nightmare of a job! Had to carry out a service on the 2009 British Gas 330 + (GC: 41-019-11) It's a Glow Worm boiler. The boiler...
I have a Glow Worm Ultracom 30sxi boiler that provides central heating and also heats a hot water tank. There are no error codes shown on the...
3K
