Discuss Soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
rocketmanbkk
Now then, I fixed a leaky pipe, ch, leak was a hole in pipe about a meter from the valve in rad. I drained down, cut pipe & soldered a new piece of pipe in. Filled up all ok (makes a change).
So, my mate whos a gas engineer said I should never solder that close to a valve without taking the pipe out if the valve.
Any comments?
I know if there's a rubber washer in a fitting, say a drain cock you should remove the rubber & then solder.
Cheers
all rubbish you solder elbows directly below etc
as above
Reply to Soldering in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys Bit of frustrating situation, I was preparing to solder a 15mm Tee by lining it up to get the positioning right, etc and it was quite...
Hi, I need some help on this shower drain installation. I’m about to install a corner shower kit in my basement bathroom. But I just found out the...
Hi, Short version: I have about 4" of pipe sticking out of a concrete floor in a cupboard. It makes a 45-degree bend as it exists (bent, not with...
I have a CH boiler installation with a nice simple vertical condensate drain, down and out through the wall to a pipe outside. All is as it...
