Discuss solar panel feeds to top of hwc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I have been asked to fit a shower for a customer. He wants a pumped unit fitted to his new en-suite.
My query concerns his solar panel heating, I've been looking and asking about the syatem he has installed.
He has a conventional single coil vented hot water cylinder fed by his boiler primaries. Nothing unconventional or difficult there.
His feed for the single solar panel is from a tee off the hwc cold feed which is pumped from this point around the panel and then directly into the top of the hwc through a reducing tee. A single check valve prevents back-flow around the circuit. The 22mm piping is reducued to 15mm as it enters the hwc.
Does anyone know if the hot water being fed into the cylinder is via a dip pipe where it blends with and is heated further before it leaves the cylinder when required? Or will the feed pipe simply terminate at the top cylinder union/take off?
I imagine it is the latter. A 15mm dip pipe would reduce flow very considerably however it would effectively cool the water leaving the cylinder. So, I'm confused.... what should I expect when I remove the top union to fit a surrey flange?
Reply to solar panel feeds to top of hwc in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I have just installed a vented McDonald 250L thermal store, it is for multi fuel but currently just connected to a standard oil boiler in...
I recently took off an end stop on the vent/expansion pipe over the heating header tank. I now know why it was capped off. When the 2 way valve...
2K
Hi This is my first post as a homeowner/DIYer Hopefully the title explains my question ; I want to replace the washer on an Essex flange as the...
2K
J
  • Locked
Hi Everyone, I'm looking for a little advice so I can try and save a bit of money this winter (especially considering the new prices!) I have an...
Hello all. I've just joined, was going to post in the new members forum, but the first site generated email sent me here... I am here, as have a...
3K
