Discuss so those ballvalves you can tee off from in steel up to the loft in the Plumbing Jobs | The Job-board area at PlumbersForums.net
WaterTight
Subscribed
them fellas were quality
why aint we chucking those chaps in no more
I can honestly say that in twenty nine years of being in the trade I've never seen one of those!
only stopped when they brought bylaw kits in
used to be loads like that as it saved having to cut another hole in the tank and you could get the overflow higher and use a smaller tank
Reply to so those ballvalves you can tee off from in steel up to the loft in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I recently did some pipe insulating in my loft. The only two I didn't do were the vent pipes. Not sure if that is the right term for them...
Hello, bit of a noob question but would someone be able to help me to understand the pipes coming off our boiler. It's a Grant oil combi boiler...
I recently read a post / comment whereby there was a recommendation that if you are away from your home more than 24 hours, then you should turn...
Would like some help please as my Drayton Wiser system is a mess. I had 2 TRVs in the lounge, one in the main bedroom, the rest of the house - 6...
Hi, I hope someone can help. I’m hoping this isn’t a permanent problem. We’ve converted a gravity vented hot water system, into an unvented...
1K
