Discuss So this fell out of my potterton Combi heatmax HE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Can anyone tell me what it is please and how to put it back?
If your boiler still works then it was just sitting in the case, this part is available as a spare on that boiler. The chances of it just falling out are slim to none.
However imo if you've had an engineer that feels it's necessary to leave an old coil in the boiler for any reason, then it won't hurt to get someone to look over it for you
As others said, it's a solenoid coil. From the gas valve, which wasn't said and you may not have guessed.
If you have a multimeter, it's worth checking it's faulty, most likely open circuit. I had one fail on my boiler a couple of years back. I didn't leave the old one lying around inside the boiler though!
Thanks guys - it was a new boiler replaced 3 years ago and no issues with it. The coil fell out about two years ago and the boiler continued to work fine. It's only now I'm renting the flat I wondered whether it was an issue.
It seems that it isn't because it's basically impossible for one to just fall out.
Thanks for all the assistance.
Sounds like it was left inside in the factory. I would still check it, and if it's OK you have a spare.
Reply to So this fell out of my potterton Combi heatmax HE in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Recently had a Viessmann Vitodens combi boiler installed, quite often when the adjacent cold mixer tap is opened the boiler starts for a few seconds! Can anyone tell me what is causing this? And how to cure?
Hi they used to say as a last resort you could discharge the D2 pipework at high level and turn it back to the wall. Similar to a combi boiler. I have just looked back through the regs this seems to have changed and it isn't mentioned now. It now mentions if at high level it should be discharged...
Boiler is SIRIUS THREE FS 70 Potterton commercial. Situation: We are small building contractors and my labourers managed to damage the radiator pipes during the strip out. Not the end of the world as damages happens. I am responsible builder and paying my bills and to repair the damages if...
