Discuss side outlet toilet bowl in the Plumbing Jobs | The Job-board area at PlumbersForums.net
AWheating
Subscribed
has anybody fitted one of these side outlet pans by H.M. James and sons?? was it a simular size to the old one you removed?
i have a very old pan to replace which is a side outlet low level like the one pictured. i cant move the drain so can either replace the pan with this or use a standard rear outlet and bent pan con which would be alot cheaper but may move the pan forward somewhat.
the drain i need to connect to is in the floor just to the side of the pan, the existing pan has a bent pan con pointing down into the drain position. Tried to get the guy to move the drain but this is going to be a cheap as possible jobbie.
BATHROOM CERAMICS LOW LEVEL P TRAP LEFT HAND TURN WC BOWL
If its for the simple solution. not the most attractive but -
what about using an angle flexi??
or am I not reading it right?
ae235
thats prob the best option tbh maybe apart from this pan. the current pan sits in front of the bathroom door and you have to squeeze past it into the bathroom. Worse shaped bathroom ive seen in a while, i was just looking for anybody who may have fitted one of these pans for opinion really. if it could save 2 inches it would be a good thing.
bathroom is an L shape, its about 1.1m wide
ifb the drain is to the side my guess is it was originally a two piece pan bnot sure if they are available any more
Johnsons continued to make a turned outlet pan in their "Trentline" range for ages after everyone else stopped doing them. That pic looks like the old Trent design - so maybe they sold the moulds to whatever asian supplier is making the H M James product?
It says on there website the make there own sutff and mentions there klins in the history bit.
know much about them ray?
there shop is in the romford rd ive never seen any sign that they make anything there
Reply to side outlet toilet bowl in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
T
Hi all, seeking advice on my toilet. (Layman here, please be gentle with me.) When we flush the loo upstairs, it flushes fine (therefore assuming...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
Hi guys. I need to replace a high level cistern/pan, for either a low level toilet or preferably a close coupled toilet. The big issue with this...
1K
Hi All, I'm new to the forum and looking for a bit of help with a new toilet I'm fitting, I'm quite a proficient DIYer but I could use some...
4K
