Discuss Siamp dropvalve .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
townfanjon
Subscribed
ehup guys , do any of you fine chaps know if the new siamp drop valves are interchangeable with the old ones , i.e. the cradle bit through the cistern base .
Thank you in advance
No idea mate. I was asking myself the same question as I have one of these to change on Monday. I am taking a close coupling kit just in case:confused::confused:
Or sell them a longer job and a fluidmaster and you won't need to replace it again in a couple of years
Yep I use Fluidmaster gear , but dont know if it will fit the Siamp cistern , its a concealed one and just dont have time .
Reply to Siamp dropvalve .......... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys. I'm trying to identify a toilet model before ordering a seat for a customer. I went to what used to be a Roca stockist (they no longer...
Hi, My current hot water system needs to be replaced. Anyone got any suggestions or can recommend any plumbers around Derrimut area that won't...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
