Discuss Showermate Negative Head Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
jaydebruyne
I installed a stuart turner showermate pump about a week ago. Was called back today as it has gotten quite noisy.
Had a look today and it is rather loud, so much so the downstairs neighbours have complained.
Any ideas? Air? Faulty unit?
I flushed the pump before I connected it to the mains.
Cheers
What is it sitting on Jay ...solid floor ..floorboards ?.....regards Turnpin:biggrin:
Shouldn`t take long to bleed air out if iso valves are fitted then you can eliminate that as the cause not that I`d imagine that is it.
Check the inlet filters to see no crap has been drawn into them
air can make it louder, and it sound be on rubber feet at the least.
Where and how is the hot feed taken?
Hot feed taken from a standard tank connector I think, cant remember ... I didnt fit from new, it was a replacement pump
Yeah both hot and cold feed had gate valves so I didnt think it was that either but thought I'd ask it anyway ...
Tank connector? The hot is normally from a dedicated flange type fitting or teed off the hot pipework at a 45 degree etc...
Gate valves are a nightmare, did they open fully as they can often seize up half shut etc
It could be teed I cant remember to be honest... I'm going back next week so I'll check. But the last pump wasn't as loud but flow sensors had gone..
I find ST customer service to be very good, worth giving them a call to see what they suggest checking and how.
Yep custard services and I've never used one before, usually Grundfos for me recommendation.. so good so far.. are filters clear clean..??
Reply to Showermate Negative Head Pump in the Plumbing Jobs | The Job-board area at PlumbersForums.net
