Discuss Shower Temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all
Some advice if possible.
I fitted a new shower yesterday (Mira ERD Realm) thermostatic type at a clients house.
Very pleased with the flow rate BUT it could be hotter. After flushing and commissioning I left the shower to run on full power ( lever turned up completely anti clockwise. I also tried to regulate the temperature by removing front plate and followed the instructions. That didn’t improve it.
A few points to note:
All other outlet hot taps get really hot even in the bathroom but not the shower
They have a combi boiler in good operation
Boiler water temp set to max
I did notice pushfit has been installed halfway up to the shower body itself then to copper.
They have one of those spa baths ,conventional bath shape under where the said shower is positioned. Didn’t get a chance to look at the pipework setup though
Can anyone offer any pointers here on what could be the issue? Most showers get hot and give off steam but this shower doesn’t get anywhere near to giving off steamy hot water. I would say it’s a bit warmer than luke warm
Cheers Andy
First check the obvious.
Hot on left?
Check filters for debris.
Does it work with just hose and no head, ie head is restricting flow?
Temporarily remove max temperature stop and wind cartridge right around - any better?
[automerge]1568814831[/automerge]
Other one, are there flow restrictors fitted - sometimes they are already and you need to remove them from the hot side.
Maximum Temperature Setting
Before using the shower the maximum temperature must be checked to make sure that it is at a safe level. It has been preset to approximately 41°C at the factory but due to variations in site conditions the maximum temperature may need adjustment.
Note! Make sure that the hot water temperature is at least 55°C and that there is sufficient supply.
  1. Turn on the shower to the maximum temperature (i.e. fully anticlockwise) and allow the temperature to stabilise.
    If the temperature is too hot or too cold, turn off the shower and adjust as follows:
  2. Make sure that the control lever is in the ‘Off’ position. Pointing downwards.
  3. Carefully unscrew the grubscrew cover and loosen the grubscrew. Remove the control lever.
  4. Turnontheshowertothemaximumtemperature by rotating the hub fully anticlockwise and allow the temperature to stabilise.
  5. Unscrew the hub retaining screw with a 2.5 mm hexagon key.
  6. Insert the 2.5 mm hexagon key into the centre of the spindle and engage with the recessed temperature adjusting screw.
  7. Rotate the hexagon key until the required maximum temperature is obtained at the shower. Turn anticlockwise to increase the temperature, or clockwise to decrease the temperature (1⁄4 turn = approximately 1°C).
  8. Oncethedesiredmaximumblendtemperature has been achieved turn off the shower.
13
9. Refit the hub retaining screw.
[automerge]1568819014[/automerge]
Reply to Shower Temperature in the Plumbing Jobs | The Job-board area at PlumbersForums.net
