Discuss Shower pump pulse in the Plumbing Jobs | The Job-board area at PlumbersForums.net
O
Old Account
Hi guys maybe someone could help me out on a Friday evening ...
i have got a twin impeller showermate eco pump.
exposed shower bat mixer with a rigid rail ...
top shower head ( ridid ) work fine
But the one with the hose attached is pulsing but only when it's attached as soon as I take the head off it's absolutely fine ...
i have a second new head with me to test because of restriction or scale
but it does the same thing
I even lifted the head up and down to see any difference... no difference
in the attic I have got a tank which feeds the house apart from the kitchen
downstairs guest toilet doesn't work at all ( it's not pumped )
ONLY shower riser is pumped ...
what can I do ?
Downstairs tap works now but still pulsing shower pump only when head is attached
:smile5:Try and run it for a while with the head removed possible air getting trapped?........regards Turnpin
Thank you turnpin,
The pump struggles to work though.
The pump is not correct installed ... 15 mm supply all the way ... :/ no flange ,
So it needs upgrading
Reply to Shower pump pulse in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, I'm in my new build 2 years and the shower pump has died. I have an air to water unit downstairs is in the utility which I've been told is...
First of all I have to confess I am not a plumber so please bear with me! I have a Daryl enclosed shower in an ensuite bathroom. It was already...
We have a gravity fed hot water system in our the house we have just recently moved into. It works fine with the downstairs shower, however we are...
A
Hey, here goes and I hope it works.. never used one of these before! I have a Sagittarius Ergo mixer shower min bar of pressure required 1 bar...
Hi All Just looking for some advice on which Exposed Thermostatic Mixer Shower (Bar Shower) would go well with the Shower Pump i'm getting...
