Discuss Shower head with adjustable spray and bottom inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
ma701ss
OK I give up, I've spent ages looking for this but can't find one. A chrome shower head with a nozzle or head that can be angled in different directions but which also has a bottom inlet for surface mounted pipework. Any suggestions please post details.
but thats for a built in BIV shower and your looking for surface one , arent you??
Ok i see what your after ,
I know look at the arm i just posted that would do would it
The good thing about the arm you can chop n change the head to suit the pressure u have ,,
The shower arm is perfect mate, didn't know the right terminology to find it before, thanks. Just need the right head now. Does the rain head allow more water flow than other heads? Want to minimise flow if possible, also does that head angle all the way straight down with the angled shower arm? A shower arm 150mm angled at 90 degrees would be better.
What about a chrome back plate? Then any shower arm, then any shower head?
Reply to Shower head with adjustable spray and bottom inlet in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We're in the process of upgrading 2 bathrooms in our house: the ensuite and the family bathroom. These adjoin one another. The ensuite is...
Hi, I've recently ripped out a full bathroom and am replacing it with new everything. The old bath was P shaped with a fixed shower head coming...
2K
Hi, I'm replacing an old concealed shower mixer valve which dripped. Trouble is the pipe inlet spacing is fixed at 130mm and the outlet pipe sits...
Simon Hall
Situation: Had a boiler system conversion. From Potterton boiler with Gledhill storage tank with on demand hot water to Veissman Combo with on...
2K
5K
