Discuss Shower Head Blocked. How to disassemble? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi. My shower head as got blocked up with limescale. I've poked pins in all the holes, soaked it in vinegar, painted it with Kilrock etc and still sections do not produce water.
Is it possible to disassemble this (and get it back together!);
Any clues as to how to take this apart?
(Or who made it so I can ask them?).
Thanks for any information
Stand it in an old bucket / measuring jug, pour Kilrock down the neck, add water and let it stand and fizz, may need to repeat.
alternatively this type of head comes with a tool to take it apart. you can see the place on the head where it goes to unscrew it for cleaning purposes.
The three holes in the side?
but where do I get a tool?
Do you know who makes the head?
Yes, I had a go at that - recycled the kilrock round a few times. I think parts are so gummed up that it will take forever to get through with this approach.
But if all else fails . . . . . . .
Reply to Shower Head Blocked. How to disassemble? in the Plumbing Jobs | The Job-board area at PlumbersForums.net
M
I have repeatedly low water pressure from my taps and shower - but only on my first floor - due to having filters blocked by some substance that is not sediment or limescale. The crystals are easily crushed and slightly waxy,slimey. I had their chemistry analysed at work. It is not sediment...
Hi all I really need some help or advise….. Back story….. Some years ago my dad had an extension to his house which included a newly built downstairs shower room. Recently he had this downstairs shower room re-fitted/decorated. Quite a simple set up consisting of a sink, toilet and shower...
I have recently fitted a thermostatic external mixer shower in my bathroom. The problem is that when it is set to the highest possible temperature its only luke warm at best. The hot water in my house is generated from a combi boiler which should be able to deliver a hot water flowrate of...
2K
Hi All I had an unvented cylinder fitted about 6 years ago. It only supplies hot water to my shower. I was hoping for a much better flow rate from the shower but it seemed no different from the original combi boiler hot feed. There is (unusually) a lever that lets me select the combi or the...
Steveo111
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled toilet with a more affordable model. This new toilet is a back-to-wall type featuring a concealed cistern within a separate unit. Since its installation...
