Discuss Should I be concerned by this gas piping connection? in the Gas Engineers Forum area at PlumbersForums.net
Hi all,
The shop below my flat has recently had gas and an external box installed. Two days ago British Gas fitted a meter then yesterday workman started drilling into box and messing with piping. The box door was left open so I had a look and took these photos.
Obviously I'm concerned about the quality of the work as this is directly below my flat. The workman are the builders converting the space below me to a flat. They have a gas safe sticker on the van.
Is this safe? who should I contact if not?
Much appreciated
Ady
Yep not to regs but upto you if you want to proceed any further as it’s not your property
Gas safe
How are they going to install the spigot tube ?
No you are not allowed to drill through a Meter Box its against the regs well in Ireland Anyway I am sure its the same in UK If you take a look on the right side of box big hole that should be sealed nothing to stop a gas leek from going into building the gas sleeve is not sealed .This hole in gas meter box is a Hazard if i came to work at this house i would nock gas off and issue a Hazard Notice
This is from august and op has never come back
Reply to Should I be concerned by this gas piping connection? in the Gas Engineers Forum area at PlumbersForums.net
Had conventional boiler and tanks removed last year and new combi fitted and just recently had it serviced but the guy who did it has given me a...
All, Belfast, Northern Ireland. I am in a bit of a predicament. I have recently had a stove fitted in a chimney that had a disconnected and...
Hi All, I need your advise as I'm really concerned here. I only just had regular boiler replaced with combi (Vaillant ecoFIT Pure 25kw). I had few...
2K
Need some advice, neighbors sewer drain keeps blocking up every few months. My wife and I have always chipped in with the other three neighbors...
Hi there, Apologies for the mammoth post but my neighbours and I really need some advice... I recently purchased a flat that was built in 2016...
