dodgem
Hi all,
This is my first post here, I've joined up to ask for advice about a new CH setup...
I don't want to hit you all with a wall of text, so I'll try and keep it short and sweet, although I've spent so long thinking about what I want to achieve that it's hard to get it into a few sentences! :wink5:
Basically, I've fitted UFH downstairs and am keeping 4 radiators upstairs. I've settled on a Vitodens 200 35kW combi boiler with VT200 weather compensator and sub-mounted mixer kit. I want to have to separate weather compensated feeds, one for the UFH and one for the radiators.
Now as I understand it, the boiler doesn't accept 'call for heat' signals when it's using the VT200 controller, so it seems that the Heatmiser system I've bought for the UFH won't work. I think I can get around this by using a low loss header and secondary pump, but it seems daft to be feeding just one circuit (the UFH) off of a LLH. So I was wondering whether I could simply connect the flow and return of the sub-mounted mixer directly to the UFH manifold and do away with the Heatmiser UFH1 controller, the manifold blending valve, the room stats, and the manifold valve actuators. Essentially just have the boiler pump water round the UFH loops continuously at a temperature that varies with outside so as to keep the rooms comfortable. I was also hoping that any differences in heat requirements between rooms (due to varying quality of insulation) could be sorted out by setting the flow rate for each loop at the manifold.
Please let me know your thoughts on this, i'm not sure if I've grasped how it's supposed to work or if I'm actually doing a good impression of a crazy person gibbering to himself!
Thanks in advance
Simon
Thanks in advance
Simon
