Discuss Secondary ecv in an apartment block in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Matt0167
Hi guys can any of you point me to the regs regarding secondary ecv to a flat
The flats are 3 storeys high with internal gas rises in a cupboard on the communial landing , This would be perfect for secondary ecv, I know it's meant to be point of entry to the flat but this is just not practical with the lay out of the apartments, the gas would enter above the front door in the ceiling and would then have to go another 15 to 20 meters to a kitchen base unit before having the secondary ecv , so would the secondary ecv in the landing riser cupboard be up to regs ?
Thanks for your help / input
The info you need is in IGE UP 2. Or regulation 9 of GS(IU) regs.
It must be as near as practicable to the point of entry of the building amongst other things.
Is this installation Commercial?
No mate it's domestic flats , just seems a bit pointless isolating inside the flat as it will only isolate the last 2 metres and boiler where as if it's in the cupboard outside isolates the whole flat
Would the cupboard be within 3 meters of the front door
Yes mate right outside the front door , but to confirm I spoke to gas safe for there input , .... Has to be within the flat not external even though the cupboard is next to the front door , and then the ecv has to be fitted at point of entry , i needed to run from the front door to the kitchen base unit in the ceiling space and locate the ecv in the base unit, this is not acceptable according to gas safe,
Now rerouting gas pipes external with risers which looks Rubbish, but complies.
Still requires an ecv if external so where’s it going ?
Reply to Secondary ecv in an apartment block in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, Excuse the length but this seems like a complicated fix. I lived in a 1930s block of flats. Brick building with concrete slab floors...
2K
Hi all, looking for some soil pipe/stack help please. I bought my first house end December and unfortunately had a toilet pipe blockage within a...
3K
Hello All and thanks Lou i did write a reply but it would not let me send it? i am not sure what I am meant to write and I do not want to come...
Hi Has any one got information on track pipe volumes and discharge rates Currently doing a 3 storey plot of flats with 3 flats per floor , I've...
Hi, some professional advice would be greatly appreciated, We are having an Unvented Cylinder installed into our 2 bedroom ground floor flat. I...
9K
