Discuss Sealing Flu going through the ceiling. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
hubsy
Hi Guys,
I have a new combi boiler, with the flue going straight up through the ceiling and roof.
The ceiling, around the flu is plywood, with a 12mm gap around the flu pipe.
What can I safely use to seal the gap?
Thanks.
Hubsy
Perhaps the same reason he put the condensate drain direct into the ground, or didn't terminate the blow off pipe outside properly, or flush the system that he put on the paperwork.
Or that he told me it had a 4yr warranty, where in fact it only has 2yrs.
He did make sure he removed every scrap of copper and brass from the old installation. But left the old tank in the loft.
Just north of Great Yarmouth.
Guy was registered and I did get the paperwork from the council afterwards.
He came recommended by friend, but I wouldn't recommend him.
Also with the heavy rain recently, I'm chasing a leak under the tiles around the flue area.
gotcha cowboy then
I'd advise getting someone else in to check your system over, it's what you can't see.
BG did a first year inspection.
Didn't take the case off,
checked flu and emissions and gas rate.
Have installed pump to take away the condensate, only outside drain is on the other side of the bungalow.
found an Alpha sealing ring, 6.5472207
will have to split it to fit it.
worcester bosch fire stop plate is very easy to fit once the flue has been installed as its in two pieces. Part number 87180069070 i think but please make sure its the right size if you order it.
its gunna cost 25-30 squids at a guess.
Reply to Sealing Flu going through the ceiling. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi, We have 28 year old Valiant Combi Boiler in our Bungalow airing cupboard, where the vertical fan flue goes up into roof. As you can see in...
Hi all, I have an old toilet on the top floor (to be removed) which empties into an outdoor vertical SVP and into the ground. The pipe is...
Hi, I've not posted for a while, not a plumber, but a keen DIYer who likes to try and do things without bodging if I can. Basically I'm wanting to...
G
Hi, had a new boiler fitted, didn’t notice at the time of fitting. you can see daylight around the overflow and condensate pipe, not an issue at...
My installation has been classed as Dangerous 'Do not use' by my boiler manufacturer. I have an Ideal Logic 30kw Combi boiler mounted as high as...
