• Thread starter T & H Plumbing
  • Start date
  • Replies 15
  • Views 127
  • head
Discuss scratching my head.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
T
T & H Plumbing
Got a call about a rad not warming up so I went
Custard says they havnt had heating on for a while and when they turned it on the rad furthest away would not get hot so
I turned all TRV off in the house and waited still no heat, bled every rad water comes out, even emptied the system to clear any air locks still no good, now I'm worried and scratching my head, I start looking at the boiler and it's behavior wall status is calling for heat and the boiler fires up does its normal routine after 5 mins the boiler ignition light goes off and comes back on every so often, is this normal? I'm proper scratching my head on this one could it be the boiler pump broken?? Any ideas would be good I've done all the basics and it's not working grrrr
Pump gone and not circulating? Overheating because heats not getting pulled from boiler
When I got to the property rads were working apart from the too farest away and looking at the system the 2 rads are a fair distance, if pump had gone would some rads still work??
I've had it before where two furthest away radiators weren't heating up and I could stop the pump quite easily. New pump In and it worked perfectly. Although I did add 3 radiators on to the system around 9 months before
Can I change a pump with not being gas safe lol or does a GSE need to do it?
I'll take that as don't go near it loool
I was gunna log valient website and put part number in and just change it but if it's too technical ill stick to fitting bathrooms :)
Reply to scratching my head.... in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hey folks, I'm in a bit of a pickle trying to set up my hot water and central heating systems. Got a gas boiler with a pressure tank and a motor...
I have a downstairs rad that has a 23 year old TRV and it's barely heating up. I bled it, and removed the TRV head and it still just gets a bit...
I have a Glowworm Ultimate 35C boiler. It shuts off at its max temp of 60C when heating radiators and the pump carries on running pumping heat...
Hi, whenever my Gloworm 18r is on even if I leave it on non-stop for 6 hours the flame symbol for the burner never switches off and the radiator...
A (if) CH system has a very high head loss due to improperly sized pipework and long runs and possibly partially blocked pipes and requires a UPS2...
