Discuss saniflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
hammers4spanner
Subscribed
Have to put in a saniflow and waste will be overflow , the big issue i have is that wont be able to use obtuse fittings to take the radius on the bends due to lack of space i have top operate in will a couple elbows in the run actually make a difference in the discharge??
I've unblocked/re-piped enough saniflow wastes to know its not a good idea.
Sent from my iPad using Tapatalk HD
Even worse having to take the pipework back out once it has been used.
Also expect them to refuse to honour the warranty if it fails because you haven't followed the instructions.
got an issue here then as only way i can get to soil pipe is to use some elbows as to use obtuse ones i lose a crucial bit of space ( why is nothing ever easy)
I recently fitted a Saniflo compact, slightly different as the waste has to be 32mm, I used swept bends after clearing this with Saniflo, could you use 32mm instead of 25mm overflow ??
Reply to saniflow in the Plumbing Jobs | The Job-board area at PlumbersForums.net
In my last posting, I requested assistance in exchanging a waste that had been fitted using silicone, without actually removing the basin. Mission...
1K
Hi, In the process of a new build and we have routed a MDPE pipe through a lintel in the DPC but unable to bend it to the correct location due to...
2K
Morning all, as always can never find an exact existing thread / discussion where I don't feel like I'm making one too many assumptions. Can I...
1K
Hi All, Looking for a bit of advice on the best way to pipe this. - 24kW Worcester regular boiler in kitchen, approx. 9 years old - unvented...
1K
Hello. This is my first ever post asking for help. I had a bathroom renovation done early this year which I did myself. I wanted to have a low...
