Discuss Saniflo Sanicompact issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
srollason
I have a Saniflo Sanicompact which is about 6 years old. If the button is pushed it appears to flush correctly and the macerator and pump sound fine. However, if water (or other liquid!) is poured into the toilet bowl the pump makes a very loud buzzing sound and doesn't pump the water away. The noise will continue until the toilet bowl is manually drained, at which point pushing the button will flush it as normal again.
It has all been completely cleaned, which doesn't seem to have made any difference to the problem (although the macerator sounded a bit rough before it was cleaned and sounds OK now when flushing).
Does anybody have any ideas as to what the cause may be and what could be done to fix it?
Thanks.
Reply to Saniflo Sanicompact issue in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a...
My toilet has been randomly doing a small flush. I've had a visit from a Saniflo engineer who has checked the unit. There is no blockage and it...
Barbara C
Hi The toliet pipes attched to the Macerator started to leak water yesterday when flushed. The macerator made a longer than noirmal whirring...
2K
Hello I have a mystery, my bathroom has a sewage smell appears to get far worse 5pm-9pm. I have plugged my bathroom/sink with plugs and its 100%...
Hello, recently our boiler stopped working properly, causing a lack of heat in our 14-radiator splitter in 3 storeys. having only one boiler at...
