Discuss Sani Split not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
H
Heathern93
Hello, I have a Sani split in my house and it is not working as it should. When I flush the toilet, the sani split makes a loud humming noise as if the motor is running but the blades are not turning. The bowl empties very slowly and after 10 minutes or so it gives up and leaves the bowl half full. The strangest thing is that after about half an hour, it kicks back in, working perfectly and clears the bowl, bit then if you flush the toilet again it goes back to the strange humming sound mentioned earlier. My main problem is here I do not know who to call as it may be a loose connection somewhere and I don't know whether a plumber will fix issues to do with wiring and I will waste money on a call out when I need an electrician. The other problem is that either the previous owners of my house or my landlord have grouted the sani split into the floor tiles, so I cannot split it apart myself even if I wanted to.
Thank you in advance for any help
We have a sani expert here but please register with the forum and repost.
Reply to Sani Split not working properly in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello, I'm a homeowner, not a DIYer. I have an almost 1 year old SaniCompact Comfort wall-hung toilet which has worked flawlessly until about a...
R
One of my toilets has air bubbles coming up every once in a while. Sometimes the toilet fills up to the top and goes down slowly. It seems to...
Hello, I'm seeking advice on resolving the persistent blockage issues with my downstairs toilet. A year ago, I replaced an 80s close-coupled...
This issue arose about a year ago. Does anyone have an idea why I occasionally hear (about once every hour or longer) a hammer related noise...
Hello all, I have just joined, after being pushed into some DIY plumbing. Here is my first plumbing DIY effort. I had a cistern lever that...
