Discuss Rotatimg soil pipe fitting in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
Hi. Could anyone advise if this is a push fit fitting that I can rotate?
If I had to cut out the section I'd have to do from below in the kitchen which might be problematic.
I've applied some wd40 in prep for when I disconnect toilet but not sure if it will move.
It certainly does look like push fit. Fittings that have been sat a while can be troublesome to move.
Bottom side looks like as glued boss so can’t rotate
I thought the top looked like push fit. Wasn't sure about the bottom that goes into another fitting.
Was thinking of using some wood as a lever. It's been in that position for 30 yrs. 😱
Really need to relocate the toilet though.
Any tips on ensuring the rest of the pipe doesn't rotate?
Easy to tell if it’s push fit will have the same collar on each outlet but that’s 100% glued sorry to say
No you might be able to remove the pipe in the boss bit but it will take time and a hair dryer and a hacksaw
No a push fit will only fit onto a pipe end.
If it's out of sight then maybe a Flexseal coupler (check exact sizes first)
Thought as much. It will be concealed so might try coupler if heating to melt glue doesn't work. It's the only toilet in the house so need to be prepared with options.
https://www.NoLinkingToThis/p/mcalpine-push-fit-single-socket-drain-connector-black-110mm/4255v
I take it something like this wouldn't squeeze in to the top of the bottom boss if I can't get it out?
That would go in nice you cut it but would leave your toilet outlet too high off the floor around 185mm from finished floor level
Use a hacksaw blade to cut internally through the wall of the pipe (just the pipe and not the boss) then heat up internally eg the pipe where you have cut and an inch in the direction your going then using a flat blades screwdriver see if you can push it in between the pipe and the boss once you get it started it becomes easier the hardiest part is the beginning once you have an inch piece you can use pliers to coil it on its self as you go with the hairdryer
Reply to Rotatimg soil pipe fitting in the Bathrooms, Showers and Wetrooms area at PlumbersForums.net
