Discuss Rofrost turbo reducer / insert external dimensions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
I make my own. The outside diameter is 42mm, the internal is the pipe diameter (15mm, 22mm, 28mm etc). There are basically two ways of doing it:
a. Turn down outside diameter to 42mm, drill / bore internal diameter to required size (ream if possible). Cut in "half" lengthways to leave one 21mm high with the flat face downwards. Other part is waste.
b. Drill / bore centre to 10mm. Use a slitting saw in a mill and cut exactly in half lengthways. Super glue both halves together. With a four jaw chuck, drill / bore ream inside diameter, turn outside diameter. Split halves, minimum waste.
Not as simple as it sounds, but the costs of aluminium bar to make a full set by method B is less than the purchase cost of a single pair.
Or even better posts me one to copy.
I will pay all postage charges.
And in return - if you are missing a size - i will get one machined for you too.
I'm happy to post you one of each size (if you need them all?)
I'm missing 1 x 15mm one. I'll happily pay postage up to you, you pay postage back to me. Sound fair?
Hallooo.
No i dont need them all.
One half of one size would do and I will mike it and from there can make any size.
Job done
Made 10 12 15 22 28 35mm
look good only prob there too shiny get to work :D
Blimey, nice work.
You should make them & eBay them. As Shaun said £56.
How much to make with time & materials?
You could have a nice little earner maybe.
[emoji106]
I have Herbert 8 but it's Easy when you have the tools
Well over the moon with it. Works like a treat..
Installed a boiler today and used it spot on.
:) good to hear how long did you leave it to freeze?
Reply to Rofrost turbo reducer / insert external dimensions in the Plumbing Jobs | The Job-board area at PlumbersForums.net
  • Locked
I bought a Rothenberger electronic pipe freezer. Used it without problems 25 or so times. Then on a job it wouldn't freeze. Took home, tested, not...
14K
Rainbow74
R
