Discuss roca comfort height cc wc set in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bolts for what?
sorry , this unit has been supplied with 2 thick 1/4" bolts that look like they tighten through pan THEN 2 smaller bolts that look like they go through cistern and screw into the 1/4" bolts?
never seen this before in 40yrs
Pic ? And you sure that's not for the loo seat
Reply to roca comfort height cc wc set in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi guys So a bit of a dilemma Normal WC Unit height 766mm which is around the average mark. quite alot of bogs lets say the flush pipe center...
I have 4 Roca dual flush plates with mechanical 2 red wire valves behind them. The only option seems to be to replace with their single option...
Pipes for thermostat shower have been fitted at different heights. Any way of rectifying without ripping all tiles. So for clarity 15mm pipes...
The soil pipe from my bathroom passes through the outside wall and into the roofspace above the adjacent single storey kitchen before dropping...
Just started gound work on self build bungalow and wondering best way to do below ground soil pipes. For toilet I was going to go straight down...
