Discuss Replacing 3-Way valve and motor on Ariston microgenus 27 MFFI in the Plumbing Jobs | The Job-board area at PlumbersForums.net
TerryWaite
I have just ordered a replacement 3-way valve for the above boiler, the part is hown below, ordered new motor too. However, it has not came with any washers/gaskets. I would have thought that when you sent a part you sent the gaskets too. Like sending a rad valve with no olives. Do I have to buy these seperate or will I get away with re-using the old ones
regards
buy from preston gas spears John always genuine parts not old polished parts without washers
For info this part also covers the Biasi 's' combi diverter valve at half the cost.
Ariston mffi never come with the washers, have replaced several and always order a pack of Regin washer ( mixture ). Change the diaphragm and the small washers at the same time ask the merchants for them
Reply to Replacing 3-Way valve and motor on Ariston microgenus 27 MFFI in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi I'm going to replace the 3 way vale on my open heating system. Hoping someone can advise. In the picture, to isolate the valve I am going to...
I'm looking for some advice on a frustrating problem I'm having with my old Eurostar 50-60s oil boiler please? Although it's old, most parts...
I need to replace a 3/4 or 22mm blending valve on a Telford Trident electric hot water boiler. see attached picture of the original part. Telford...
M
Hi, Hopefully someone can throw some light on if this is a real issue or not. I have had this boiler for about 10 years, I noticed just recently...
I have an old Potterton suprima boiler with a hot water tank and pump. We have hot water but no heating, the light on the boiler is showing amber...
2K
