Discuss Replace ancient Honeywell mechanical thermostat with a Honeywell T3R in the Central Heating Forum area at PlumbersForums.net
I would like to replace my ancient Honeywell mechanical thermostat with a Honeywell T3R PROGRAMMABLE THERMOSTAT
I have three wires in the old thermostat. Please see the first three photos.
1 Red
3 Yellow
2 Blue
are these
1 Live
3 Live return (Switched)
2 Neutral
Could I configure it as in the combi boiler option with a separate power supply and connect Red to A and Yellow to B as the Red wire is not always live and Blue terminated/Isolated (Not used)
or
Option 1 and leave the controller, which is a Seimens RWB29 heating on constant and control it from the T3R
Red to L and L linked to A
Yellow to B
Many thanks for your time
You'd find the thermostat wires (prob in airing cbd) and terminate/link out red and yellow.
Either fit relay inplace of existing timer or terminate those wires in airing cbd and fit relay there.
Patch old holes in walls and fit new thermostat in livingroom
Reply to Replace ancient Honeywell mechanical thermostat with a Honeywell T3R in the Central Heating Forum area at PlumbersForums.net
Hi I have a Honeywell ST699 programmer which is working fine but I want to learn how to decommission it (disconnect it from the rest of the...
Hi, I live in a really remote part of the Highlands, so paying for a plumber (or electrician?) to do this will be brutally expensive, so I need to...
Hi I'm replacing my old dial thermostat with a digital The wires going in from left to right are Earth Blue 2x Black Brown When electrically...
M
We’re trying to connect a nest generation 3 to our ideal boiler. At the moment it’s wired to a honey well R6660D receiver the connections inside...
Deleted member 120897
Hi, We moved into our house last year and our current central heating set up is: Boiler: Vokera Mynute HE system boiler Thermostats: 2x Robus...
