Discuss Repairing holes in tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all,
If i am asking in wrong forum apologies, just wondered, i have removed and replaced customers whb and there are unfortuantely two holes where old fixings used to be, any ideas on making good these unsightly holes in white tiles? Other than pumping silicone in there:)
difficult to hid,if you try to blend in sometimes looks worse,how about just sticking some white or chrome plastic screw cap tops over or slightly bigger discs
Copperman hello m8 listen you can fill them with a bit of polyfilla sand down smooooooth get yourself to a wilko or a hardware/paintshop and buy a tin of white enamel paint that should do the trick bruv.
P.s cut out a bit of paper for a template slightly larger than the hole. Then spraywith enamel wait to dry. Add a bit of car polish buff at least 4 tiles surrounding the two said tiles,depending on size and bosh! your in the clear.Sometimes i do get it right.
be professional and do the job properly, chop them out and replace
Reply to Repairing holes in tiles in the Plumbing Jobs | The Job-board area at PlumbersForums.net
