Discuss reillo rdb control box in the Plumbing Jobs | The Job-board area at PlumbersForums.net
B
bigwave167
have been given a spare burner but there is 3 wires going to control box,live,neutral and a black wire??? Can someone enlighten me ??
Maybe one is discoloured.
Forget about blak wire unless you have a remote lockout alarm (which means if you have a light or buzzer in your house to warn you of a failure on your boiler)
Wire up as normal
RJSCAN
you cant ignore the black wire it becomes live (240vac) if and when the boiler ever locks out, put a terminal block on it and make it safe if your not going to use it.
Reply to reillo rdb control box in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All I have a leak coming from within my Mira Elite QT shower. It seems to be flowing from behind the switching Control. Any ideas what could...
Hi. I need a new toilet supply line but don’t know the size type of the fitting at the shut off valve. It is not 3/8 compression. It is a plastic...
