Discuss Regin 45 premier fluid refill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
bassmonster
hi all,
i've got the regin 45 premier gauge and for some reason, i cannot zero it. seems like i've lost some fluid but i don't know how...
i'll obviously need to buy refill. does anyone know how to refill? do i unscrew the black screw on bottom left?
Thank you. :biggrin:
i just put a bit at a time in the top left. you zero it via the bottom left grub screw..unscrew it half way top it slowley. when youve done zero it...sorted.
I've been using Absinthe for years in my premier. Buy loads of it tho, always running out?
Put the fluid in 1 drop at a time.
It's amazing how little it takes to top up.
it needs to be the same specific gravity. if anti freeze is ill save a fortune.
Regin premier fluid has an SG of 1.88, antifreeze has an SG of 1.1088. Looks the same, won't do the same job.
Reply to Regin 45 premier fluid refill in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all, I wonder if someone can help. We have a Worcester MT10 combi boiler that has a fault with the expansion vessel. The landlord is having...
Dear All New member here, coming looking for help. A few weeks ago I had work carried out by a British Gas Homecare service technician. It...
As part of a slow DIY bathroom refit I've removed the old toilet from the original location next to the soil pipe (and obviously capped off the...
So I bought my first flat recently (am in UK) and in a bit of a pickle as the bathroom has turned up lots of problems that weren't picked up by...
5K
