Discuss rayburn pipework direct to rads in the USA area at PlumbersForums.net
Can i connect on a woodfired rayburn suppreme's radiators central heating pipes flow and pumped return direct into the rayburn's flow and return hot water tank plpes and should i fit a injector tee and if i do would it be better as close to the rayburn itself
Uncontrolled heat sources, such as you wood fired Rayburn, require specialist installation.
Too many things to go wrong and when they do go wrong, they go wrong in a very bad way.
If you have no, or limited experience with the setup of these type of installations, then get someone who has.
I hope you're not in the same boat with the people that paid a small fortune for the appliance and are required to pay a 'Kings Ransom' for a correct and required installation.
PS: Small Fortune & Kings Ransom were terms used by a customer of mine to me in an email, when I quoted her the connection of her new Rayburn stove to her existing heating system.
no .its a general question a neighbour wants to take out a old oil boiler which is installed where a rayburn used to be but the boiler central heating pipes go through concrete wall to under the floor boards .So to keep it simple can they not be connected to hot water tank pipes, would it not be much different if the range cooker had flow and return on both ends
As has already been said needs carefully system design.
Dependent on output of rayburn correctly sized heat leak radiator required.
Injector tee's common on this type of cooker (we used to make our own)
Normal to have both high limit and low limit pipe thermostats to run pump.
Reply to rayburn pipework direct to rads in the USA area at PlumbersForums.net
