Discuss Radiators keep getting pin holes in them. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
armyash
Subscribed
Hi guys,
Had to go and replace a radiator this afternoon, it's the second one I have done there in 3 months and I believe a couple more were replaced before that. Some were only 6 months old.
The customer had a flush done within the last 2 years and says the problem has got worse since. I have taken a sample so we can test the PH levels. (I think that's what we are testing).
The colour of the water I had out today was a light brown which i think could be rust from the rads if they are rusting.
It's very strange, anyone come across anything similar?
Cheers.
Depending what was used, I think some go inert after time, if it was an acidic based cleaner like DS40 then you've got a problem.
I'm going to suggest a chemical flush (with plenty of flushing) and adding more inhibitor.
Won't be up to me what we do but that's what i'd try.
I'd guess it's either pumping over
Or a leak somewhere and fresh water getting in all time
Is the corrosion inhibitor concentration correct? Some corrosion inhibitors (anodic inhibitors), whilst providing excellent control at the correct concentration, can cause pitting corrosion if underdosed. It can be difficult to estimate the system volume so the corrosion inhibitor concentration is best determined by analysis.
Failure of coil in copper cylinder?
Try converting to sealed system if overpumping.
Thanks for all the replies hopefully I will get to find out what's going on before the end of tomorrow.
All copper. Thanks for the reply.
some things you need to check,brown water is oxygenated water,so fresh waters constantly getting into the system
1,low head,htg cwsc to close to the boiler,not enough head system pumping over constantly
2,pump failing or overset or system corrosion
3,system design issue(see 1)
4,coil in cylinder failed but if both tanks(cwsc)are at the same level this is not possible,if the htg tank is higher than the domestic tank then it is
Thanks for that, plenty to go on!
What ever caused it, the damage is done. Probably have to fit all new rads and sort out water quality and make sure air is not oxygenating the water.
Ash, if your company is boggled over it you could have elector consult
Chris is at sitting bourne, he also runs vietec heating
heating-water.co.uk
going for a curry with chris and a bunch of other installers soon.
heating-water.co.uk
Thanks for the heads up killy.
Didn't get to test it today, too busy on other jobs.
Reply to Radiators keep getting pin holes in them. in the Plumbing Jobs | The Job-board area at PlumbersForums.net
