Discuss Radiators cold at bottom in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi everyone
Looking for some advice please
I have Worcester Bosch green star 38cdi classic HB combi boiler.
It’s only a few years old and has a magni clean thingy fitted to collect the metal etc.
I have bled all radiators most rads bar 2 small ones 400mm x 400mm (old) are all brand new 2 panel 1 convector, all pipe work is 15mm no microbore
The upstairs rads get extremely hot almost too hot too touch, most the downstairs ones do as well apart from about 3 - I have turned all locksheilds down to virtually off about a quarter a turn open and these still get red hot. This improved the downstairs ones that were cool but still hasn’t solved the issue. Im wondering if I need a bigger pump fitted?
The rads have been taken off and flushed out there is no sludge issue here the boiler is only about 4 years old.
Does anyone have any suggestions or what it may be.
Thanks in advance
This is my
Pump
As mentioned above the cover forms a part of the combustion seal please call a gsr engineer to take a look and ensure the cover is replaced suitably
Could be undersized pipework, could be two rads teed off the same feed, whilst unlikely it could be muck in the rads
Itll be either teed off another 15mm feed and the pipework doesn’t have enough heat capacity to heat two rads or the system just needs balancing
I have turned all locksheilds on the radiators that get piping hot to virtually off like a very slight turn open and these still stay hot.
I assume this is how you balance?
The ones in question and in regards to them potentially being teed off are in various places of the downstairs and seems unlikely they could be teed off one another - clearly i don’t know and am not a plumber.
Is my suggestion about bigger pump or turning up something that would help?
You won't need a bigger pump, you've got 9 radiators so the pump in the boiler is more than adequate. Boilers 4 years old so unlikely needs the pump changing at all. Without us physically seeing the job it's hard to say but from what you've said, if balancing isn't solving the issue but your radiators work when everything else is turned off, it points to pipe sizing.
Ok thank you very much.
So if I have a 22mm main piping with 15mm pipes to rads.
What would be adequate pipe sizing?
Thank you
That’s adequate but if two rads are teed off one 15mm feed then it’s immediately splitting the kw out put
Also when one of you guys mentioned earlier poor pipe work do you mean size wise or did you mean like to pipes being run round to many bends etc like having to many elbows etc to go around or wouldn’t that effect it.
Well it could be either, as mentioned before we can't say for certain without seeing the job but you have poor flow to a couple radiators. Could be incorrect pipe sizing, could be too much restriction caused by numerous elbows in the pipe work. There could be isolation valves under the floor somewhere or a kinked pipe you may have faulty trv valves or partially blocked lockshieds. The list is endless. You've ruled out balancing and air locks. Consider taking the radiators off that aren't working and opening both the flow and return pipes to see what sort of flow rate your getting through the valve.
I see,
I’ve done this to a certain degree. The radiators get warm across the top and I can hear the water thumping in when I empty it and then fill it back up. It almost seems like the water is not being sucked out the opposite side to the TRV again sorry if this sounds silly but I’m not a plumber.
Appreciate your help and responses
Reply to Radiators cold at bottom in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi all. I noticed this winter my living room rad only get hot in the top half. Radiator is 1600mm(DP SC) double panel single convector. System was flushed just last year. Both flow and return values are fully open and don't stick. Boiler is serviced each year. Baxi combi boiler about 8 ton9...
Hi - I'm a reasonably experienced DIY plumber but just can't work out why the last new rad I've installed is cold - would really appreciate your help please. I've extended an existing 'run' of radiators - the last one on the run ( in downstairs kitchen) is cold. The first rad added is...
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was not working. He changed both valves and still the radiator was not working. He put some chemicals in and said it should break up anything that is...
Hi. Turned my heating on for the 1st time today, i bled every radiator as haven't done it since last winter. upstairs worked fine but an hour or 2 later I noticed downstairs was still cold. I looked for some advice online and turned the trv's off and locksheilds for the upstairs only and...
I have a downstairs rad that has a 23 year old TRV and it's barely heating up. I bled it, and removed the TRV head and it still just gets a bit warm. It seems to be warm over all the rad, not just at the bottom. The rest of the system heats up fine with the other rads getting hot. It's sealed...
