Discuss Radiator rattling even if closed off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sulking1
Hello,
i've got this horrible radiator that keeps rattling like a tapping noise when the heating is on, it will rattle every 20mins and even if i turn the valve off together with the lock shield it will still rattle ??
obviously it won't rattle when the heating is off
anyone help i'm going to try a flush or just replace the radiator but any suggestions its just one radiator in the main bedroom all others are fine.
thanks.
Hello
Could be expansion/ contraction creep, are the plastic inserts fitted where it hooks on to the radiator bracket?
Gary
Yes the inserts are all there, if i push onto the rad it still does it.
check and secure (with hair felt between pipe and any timber) the pipework leading to the rad and others near by.
it could also be another valve on the system causing small vibrations and that rad and pipework to it is just being effected most by it.
if it has a trv it could be one that flows one way only and is on the wrong way round, that makes em rattle like hell :)
Either pipe expansion when heating is on or single way thermostatic valve. try removing trv head if fitted.
Reply to Radiator rattling even if closed off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi All, In Dec 2023 I had my annual boiler service and asked the plumber to change 2 radiator valves as the radiator in the toilet downstairs was...
I am trying to workout in what order my radiators heat up in order to then balance them. I am able to figure out which radiator pipe is the...
Hi, Sorry if question already answered in previous posts, but I can't find a solution to the below: We recently moved house to a new home that...
H
Hi! If anyone is able to give any advice it's hugely appreciated! I'm in the UK if that makes a difference. I have a condensing combi boiler...
O
Hi All, We renovated our house in 2019 and put in completely new plumbing system and piping including new boiler and 9 radiators. Off those...
