Discuss Radiator rattling even if closed off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
sulking1
Hello,
i've got this horrible radiator that keeps rattling like a tapping noise when the heating is on, it will rattle every 20mins and even if i turn the valve off together with the lock shield it will still rattle ??
obviously it won't rattle when the heating is off
anyone help i'm going to try a flush or just replace the radiator but any suggestions its just one radiator in the main bedroom all others are fine.
thanks.
Hello
Could be expansion/ contraction creep, are the plastic inserts fitted where it hooks on to the radiator bracket?
Gary
Yes the inserts are all there, if i push onto the rad it still does it.
check and secure (with hair felt between pipe and any timber) the pipework leading to the rad and others near by.
it could also be another valve on the system causing small vibrations and that rad and pipework to it is just being effected most by it.
if it has a trv it could be one that flows one way only and is on the wrong way round, that makes em rattle like hell :)
Either pipe expansion when heating is on or single way thermostatic valve. try removing trv head if fitted.
Reply to Radiator rattling even if closed off in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hi Does anyone recognise the make/brand of the radiator valve. It leaks when closed and Iam hoping I can replace a seal etc?
PSxxxxxx
