Discuss Radiator problem , in the Plumbing Jobs | The Job-board area at PlumbersForums.net
Hello
my first post so be gentle with me
the radiator in the bathroom was working fine untill the other day when suddenly it was only lukewarm (the inlet pipe was hot though ) the next day it was cold at the top so bled it with the heating off , today cold as the grave all over , you use to hear the water going through it .
All the other rads are fine , tried turning them down no difference , the rad on the landing out side the bathroom is boiling hot even if i turn the thermostat right down ?? however the thermostat on that one and the bathroom are quite old looking .
advice please , it is a oil system with tank in the attic / not combi
regards and thanks in advance
Turn all the other rads off and leave the bathroom one turned on, if pump is multi speed, turn it up to highest
If air locked, this should shift it
If the trv,s are very old, there's a chance they're siezed, sometimes a light tap on the side of the valve can free them
Or take the trv head off and try and physically pulling the pin in and out, If that sounds daunting, call a plumber
Reply to Radiator problem , in the Plumbing Jobs | The Job-board area at PlumbersForums.net
